Your basket is empty
Kingston 16GB 1866MHz DDR3 CL9 DIMM (Kit of 2) XMP HyperX Predator
Quicklinx: C58GWS00 Mfr#: HX318C9PB3K2/16
Type: DDR3 SDRAM
Capacity: 16GB
Connection: DIMM 240-pin
Speed: 1866MHz
Data Integrity: Non-ECC
Hurry, only 1 left in stock!
£98.59 ex VAT
£118.30 inc VAT
HyperX® Predator memory has the fastest speeds, lowest latencies and highest capacities available in HyperX memory. It’s designed for and compatible with all popular brands of motherboards. HyperX Predator is ultra-reliable and 100 per cent factory tested to ensure that it will deliver higher performance, ultraresponsive multitasking and a faster system.Predator features a tall heat spreader for greater heat dissipation, and its black PCB complements the look and design of the latest PC hardware. Intel XMP-certified kits are available up to 2800MHz. Users can overclock their platforms simply by selecting a profile, with no need for manual adjustments in BIOS.For added peace of mind, HyperX Predator is backed by a lifetime warranty, free technical support and legendary reliability.
Kingston HyperX Predator - DDR3 - 16 GB : 2 x 8 GB - DIMM 240-pin
RAM memory
16 GB : 2 x 8 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz ( PC3-14900 )
Latency Timings
CL9 ( 9-10-11 )
Heat sink, dual rank, eight banks, Serial Presence Detect (SPD), Intel Extreme Memory Profiles (XMP) , unbuffered
Voltage
1.5 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
16 GB : 2 x 8 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
1.614
Speed
Latency Timings
CL9 ( 9-10-11 )
Non-ECC
Module Configuration
1024 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
RAM Performance
SPD - 1600 MHz - 1.5 V - CL11 - 11-11-11 , Intel Extreme Memory Profiles (XMP) - 1600 MHz - 1.5 V - CL9 - 9-9-9 , Intel Extreme Memory Profiles (XMP) - 1866 MHz - 1.5 V - CL9 - 9-10-11
Colour Category
Kingston 16GB 1866MHz DDR3 CL9 DIMM (Kit of 2) XMP HyperX Predator Bundle deal on Kingston 16GB 1866MHz DDR3 CL9 DIMM (Kit of 2) XMP HyperX Predator
£114.91
saving £7.71
Type: DDR3 SDRAM
Capacity: 16GB
Speed: 1866MHz
Registered/Buffered: Unbuffered
CAS Latency: CL9
Standard: PC3-14900
Brand: Kingston
Price Range Ex VAT: 50 - 100
