Product
Brand
Kingston 16GB 1600MHz Reg ECC Low Voltage Module
Quicklinx: 9GZBWS00 Mfr#: KTD-PE316LV/16G
Designed with your specific system in mind, Kingston system-specific memory makes it easy to select exactly what you need, based on your OEM system brand and model. Kingston engineers use only the highest quality components on the market to ensure maximum performance and legendary Kingston reliability. All Kingston system-specific memory is guaranteed to be compatible with the system for which it was designed – which takes the hassle out of selecting memory for your notebook or desktop.
Kingston - DDR3L - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
System specific
Data Integrity Check
ECC
Speed
1600 MHz (PC3L-12800)
Latency Timings
CL11
Dual rank, Low Voltage, registered
Voltage
1.35 V
Limited lifetime warranty (Russia - 10 years)
Dell PowerEdge C1100, C2100, C6100, C6220, C8220, M420, M520, M610, M620, M710, M820, R320, R410, R420, R510, R520, R610, R620, R710, R720, R815, R820, R910, R920, T320, T410, T420, T610, T620, T710; PowerVault NX400; Precision R5500, R7610, T3610, T5500, T5610, T7600, T7610
16 GB
Upgrade Type
System specific
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
2048 x 72
Chips Organization
X4
Voltage
1.35 V
Compatible Slots
1 x memory
Dell PowerEdge C1100, C2100, C6100, C6220, C6220 II, C8220, C8220 Compute Sled, C8220X, M420, M520, M520P, M610, M610x, M620, M620P, M710, M710HD, M820, R320, R410, R420, R420xr, R510, R520, R610, R620, R710, R720, R720xd, R815, R820, R910, R920, T320, T410, T420, T610, T620, T710 , Dell PowerVault NX400 , Dell Precision R5500, R7610, T3610, T5500, T5610, T7600, T7600 Advanced, T7600 Base, T7600 Essential, T7610
