Your basket is empty
Kingston 16GB 1600MHz DDR3L ECC Reg CL11 DIMM DR x4 1.35V w/TS
Quicklinx: C65HWS00 Mfr#: KVR16LR11D4/16
Type: DDR3L SDRAM
Capacity: 16GB
Connection: DIMM 240-pin
Speed: 1600MHz
Data Integrity: ECC
10 in stock
£112.04 ex VAT
£134.44 inc VAT
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3L - 16 GB - DIMM 240-pin
RAM memory
16 GB
Memory Type
DDR3L SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
1600 MHz (PC3-12800)
Latency Timings
CL11
Temperature monitoring, dual rank, registered
Voltage
1.35 V
Lead Plating
Gold
16 GB
Upgrade Type
Generic
DRAM
DDR3L SDRAM
DIMM 240-pin
Speed
Latency Timings
CL11
ECC
Module Configuration
2048 x 72
Chips Organization
X4
Voltage
1.35 V
Lead Plating
Gold
Compatible Slots
1 x memory - DIMM 240-pin
Kingston 16GB 1600MHz DDR3L ECC Reg CL11 DIMM DR x4 1.35V w/TS Bundle deal on Kingston 16GB 1600MHz DDR3L ECC Reg CL11 DIMM DR x4 1.35V w/TS
£128.05
saving £8.87
Type: DDR3L SDRAM
Capacity: 16GB
Speed: 1600MHz
Data Integrity: ECC
Registered/Buffered: Registered
CAS Latency: CL11
Standard: PC3-12800
Brand: Kingston
Price Range Ex VAT: 100 - 150
