Your basket is empty
Kingston 16GB (4 x 4GB) HyperX Predator 1866MHz DDR3 240-pin DIMM CL10 XMP
Quicklinx: 9BQRWS00 Mfr#: KHX18C10T2K4/16
Type: DDR3 SDRAM
Capacity: 16GB
Connection: DIMM 240-pin
Speed: 1866MHz
Data Integrity: Non-ECC
£83.99 ex VAT
£100.78 inc VAT
Marketing description is not available.
Kingston HyperX Predator - DDR3 - 16 GB: 4 x 4 GB - DIMM 240-pin
RAM memory
16 GB: 4 x 4 GB
Memory Type
DDR3 SDRAM - DIMM 240-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1866 MHz (PC3-14900)
Latency Timings
CL10 (10-11-10)
Heat sink, single rank, eight banks, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), dual channel, quad channel, unbuffered
Voltage
1.5 V
Lead Plating
Gold
16 GB: 4 x 4 GB
Upgrade Type
Generic
DRAM
DDR3 SDRAM
DIMM 240-pin
Module Height (inch)
2.12
Speed
Latency Timings
CL10 (10-11-10)
Non-ECC
Module Configuration
512 x 64
Chips Organization
512 x 8
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
4 x memory - DIMM 240-pin
Kingston 16GB (4 x 4GB) HyperX Predator 1866MHz DDR3 240-pin DIMM CL10 XMP Bundle deal on Kingston 16GB (4 x 4GB) HyperX Predator 1866MHz DDR3 240-pin DIMM CL10 XMP
£100.31
saving £8.65
Type: DDR3 SDRAM
Capacity: 16GB
Speed: 1866MHz
Registered/Buffered: Unbuffered
CAS Latency: CL10
Standard: PC3-14900
Brand: Kingston
Price Range Ex VAT: 50 - 100
