Get in the game with HyperX FURY. Even newbies get up to speed fast, since FURY automatically recognises its host platform and automatically overclocks to the highest frequency published - up to 1866MHz - providing plenty of power for your next deathmatch. Affordably priced, FURY's asymmetric heat spreader design is available in black, blue, red and- for the first time in the HyperX line -white, with a black PCB. It's 100 per cent tested and backed by a lifetime warranty and free technical support.
- Asymmetric heat spreader for stylish heat dissipation
- Compatible with Intel and AMD platforms
Features & Benefits
- Unique -- tested with all popular brands of motherboards
- Easy to install -- Plug-and-Play functionality
- Automatic overclocking -- reach faster speeds and higher capacities just by installing the memory, no adjustments in BIOS needed
- Reliable -- 100 per cent factory tested
- Lifetime warranty, free technical support
- Capacity 16GB
- Frequency speed 1600MHz
- CAS latency 10-10-10-30
- Voltage 1.5V
- Operating temperature 0C to 85C
- Storage temperature -55C to 100C
- Dimensions 133.35mm x 32.8mm
- Compatible with P55, H67, P67, Z68, Z77, Z87 and H61 Intel chipsets, as well as A75, A87, A88, A89, A78 and E35 AMD chipsets
Get in the game faster with automatic high overclocking. -
Aggressive look, asymmetrical design
Its innovative design makes HyperX FURY DDR3 memory stand out from the crowd. Its asymmetrical heat spreader and PCB complement the look of many systems.
- HyperX FURY - DDR3 - kit - 16 GB: 2 x 8 GB - DIMM 240-pin - 1600 MHz / PC3-12800 - unbuffered
- Product Type
- Memory kit
- Capacity
- 16 GB: 2 x 8 GB
- Memory Type
- DDR3 SDRAM - DIMM 240-pin
- Upgrade Type
- Generic
- Data Integrity Check
- Non-ECC
- Speed
- 1600 MHz (PC3-12800)
- Latency Timings
- CL10 (10-10-10-30)
- Black PCB, FURY asymmetric heatspreader, unbuffered
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 16 GB: 2 x 8 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR3 SDRAM
- Form Factor
- DIMM 240-pin
- Module Height (inch)
- 1.29
- Speed
- Latency Timings
- Non-ECC
- Module Configuration
- 1024 x 64
- Voltage
- 1.5 V
- Lead Plating
- Gold
- Compatible Slots
- 2 x memory - DIMM 240-pin
- Colour Category
- Black
