Kingston 16GB (2 x 8GB) 1333MHz DDR3 Non-ECC SODIMM CL9
Quicklinx: 93FYWS00 Mfr#: KVR13S9K2/16
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR3 - kit - 16 GB: 2 x 8 GB - SO-DIMM 204-pin - 1333 MHz / PC3-10600 - unbuffered
Memory kit
16 GB: 2 x 8 GB
Memory Type
DDR3 SDRAM - SO-DIMM 204-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
1333 MHz (PC3-10600)
Latency Timings
CL9
Unbuffered
Voltage
1.5 V
Lead Plating
Gold
16 GB: 2 x 8 GB
Upgrade Type
Generic
DRAM memory kit
DDR3 SDRAM
SO-DIMM 204-pin
Speed
Latency Timings
CL9
Non-ECC
Unbuffered
Module Configuration
1024 x 64
Voltage
1.5 V
Lead Plating
Gold
Compatible Slots
2 x memory - SO-DIMM 204-pin
