Kingston 128GB SSDNOW KC400 SATA 6Gb/s 2.5" SSD Upgrade Kit
Quicklinx: BVQBWS00 Mfr#: SKC400S3B7A/128G
Kingston's KC400 SSD is faster than a hard drive to deliver consistent performance for both compressible and incompressible data and improve responsiveness in performance-hungry applications. It uses a powerful processor to speed up daily tasks and improve productivity. KC400 provides end-to-end data path protection and SmartECC to guard data, plus SmartRefresh to protect against read errors. Data is rebuilt if there's an error, and the drive is able to recover from an unexpected power shutdown, thanks to firmware-controlled power loss management. Advances in controller technology and NAND give this drive excellent data reliability.
Kingston SSDNow KC400 Upgrade Bundle Kit - solid state drive - 128 GB - SATA 6Gb/s
Solid state drive - internal
128 GB
2.5" (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, Phison PS3110-S10 controller, Advanced Smart ECC, Firmware-based Power-Loss Protection, S.M.A.R.T.
69.9 mm x 100.1 mm x 7 mm
60 g
5-year warranty
128 GB
2.5"
SATA 6Gb/s
69.9 mm
100.1 mm
7 mm
60 g
Performance
SSD Endurance
150 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 450 MBps (write)
4KB Random Read
88000 IOPS
4KB Random Write
87000 IOPS
Maximum 4KB Random Write
87000 IOPS
Maximum 4KB Random Read
99000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" or 3.5" (with included bay adapter)
Power Consumption
3.74 Watt (active) , 0.255 Watt (idle) , 0.335 Watt (average)
Software Included
Drivers & Utilities
2.5" SATA enclosure, 3.5-inch bay adapter, 2.5mm mounting spacer
1 x USB cable , 1 x Serial ATA power adapter - internal , 1 x Serial ATA cable - internal
Mounting Kit
Included
Limited warranty - 5 years , Technical support
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
