Kingston 128GB microSDXC UHS-1 Class 3 (Adaptor included)
Quicklinx: BYN9WS00 Mfr#: SDCA3/128GB
Impressive speeds to capture high-quality video.
Kingston’s microSDHC/SDXC UHS-I U3 90R/80W Flash memory cards deliver fast, UHS-I Class U3 speeds up to 90MB/s read and 80MB/s write that let you capture cinema-quality Full HD (1080p), Ultra HD (2160p), 3D and 4K videos on high-performance small form factor devices such as smartphones and GoPro® cameras. It’s also great for live television broadcasts and recordings. The cards offer faster upload and editing times, especially with USB 3.0 card readers. Higher sustained write speeds ensure video integrity and let photographers shoot in continuous burst mode.
Use the optional adapter to take advantage of standard SD card size SDHC/SDXC host devices, such as DSLRs, video cameras and larger tablets. The microSDHC/SDXC UHS-I U3 90R/80W is built to be durable, so you can rest assured that your photos, videos and other important files will be protected, even in harsh environments. This versatile card is tested to be waterproof, temperature proof, shock/vibration proof and X-ray proof. Multiple capacities up to 128GB provide plenty of room for longer recording time for HD video and space for thousands of high-resolution photos and hours of video.
  • Fast UHS-I Class U3 speeds up to 90MB/s read and 80MB/s write
  • Small form factor card has optional adapter for standard-size devices
  • Tested for durability and to withstand the elements
  • Multiple capacities up to 128GB
  • Fast performance
    UHS-I Speed Class 3 - up to 90 MB/s read and 80 MB/s write for continuous shooting, video recording and fast file transfer.
  • Resistant
    Waterproof, shock proof, X-ray proof and temperature proof to perform even in harsh environments.
  • Flexible/Multi-functional
    When combined with the SD adapter, can be used as a full-size SDHC card to fit in DSL-R or DSL-M cameras, 4K camcorders and other devices.
Kingston - flash memory card - 128 GB - microSDXC UHS-I
Flash memory card
microSDXC UHS-I Memory Card
Storage Capacity
128 GB
Speed Rating
UHS Class 3
Included Memory Adapter
microSDXC to SD adapter
Flash memory card
Storage Capacity
128 GB
Speed Class
UHS Class 3
Read Rate
Up to 90 MB/s
Write Rate
Up to 80 MB/s
Shockproof, waterproof, vibration-proof, X-ray-proof, temperature-proof
Limited warranty - lifetime
11 mm
15 mm
Thickness
1 mm
-25 °C
85 °C
