Product
Brand
Kingston 128GB IronKey W300 WTG USB 3.0
Quicklinx: BZT6WS00 Mfr#: IKW300/128GB
IronKey's 'PC on a Stick' allows the user to boot a fully functioning Microsoft Windows 8 desktop directly from a trusted IronKey USB flash drive. IronKey Workspace W300 transforms any computer into your employees’ own personal workspace capable of using all host system resources. It enables employees, contractors and field personnel to use a corporate IT Windows image, complete with all your organization’s applications, from virtually any computer. Windows To Go allows you to provide your users with a fully functional version of Windows 8 that mirrors your corporate desktop. And by provisioning Windows To Go devices through Windows 8 Enterprise, you can ensure employees, partners and contractors are using mobile workspaces created and managed by IT. Rely on the Microsoft-certified Windows To Go device built around Imation’s expertise in portable workspace solutions. Rugged IronKey Workspace W300 devices are built to stand up to the elements, and they feature password protection capabilities and up to 256-bit AES full disk encryption leveraging Microsoft BitLocker technology. And with IronKey Workspace W300 devices, data and applications are automatically provided strong protection from breach and corruption the moment users remove flash drives from their host PCs. IronKey Workspace W300 delivers 5x the minimum average read/write speeds required for Windows To Go certification. And it’s booting genuine Windows - ensuring widespread adoption and user satisfaction, and delivering a fast desktop experience without the performance drag of desktop virtualization. IronKey Workspace W300 does not include Microsoft Windows. Requires Microsoft Windows 8 Enterprise Edition.
IronKey Workspace W300 - USB flash drive - Windows To Go certified - 128 GB
USB flash drive
Interface Type
USB 3.0
Storage Capacity
128 GB
Hardware Encryption
Encryption Algorithm
128-bit AES, 256-bit AES
Microsoft Windows 7 or later
Windows To Go Certification
5 years warranty
USB flash drive
Storage Capacity
128 GB
Hardware Encryption
Compatibility
Non-specific
Read Rate
Up to 400 MB/s
Write Rate
Up to 316 MB/s
Interface Type
USB 3.0
Encryption support, bootable, password protection, shockproof, waterproof, dustproof, ruggedized, metal body
Limited warranty - 5 years
81 mm
21 mm
9 mm
20 g
70 °C
