Kingston 128GB HX Savage USB 3.0
Quicklinx: BS1PWS00 Mfr#: HXS3/128GB
HyperX Savage USB Flash drive offers blazing fast speeds of up to 350 MB/s to save time during file transfers and let you quickly access, edit and transfer files from the drive without any performance lag. It's compliant with USB 3.1 Gen 1 specifications to take advantage of USB 3.1 ports in desktops and notebooks and also backward compatible with USB 3.0 and USB 2.0. HyperX Savage is a stylish drive, with a sleek black casing and signature HyperX logo in red and an aggressive look. It's designed to work on multiple platforms and game consoles, including PS4, PS3, Xbox One and Xbox 360.
  • Blazing fast transfer speeds
    HyperX Savage delivers blazing transfer speeds of 350 MB/s read and 250 MB/s write to save time and let you quickly access files with no performance lag.
  • USB 3.1 Gen 1 functionality
    HyperX Savage is compliant with USB 3.1 Gen 1 specifications to let you take advantage of USB 3.0 ports in newer notebooks and desktops.
  • Bold design
    This stylish drive has an aggressive look that complements the latest PCs and consoles. Its sleek black casing is accented with the signature HyperX logo in metallic red.
  • Multi-platform compatibility
    Use this versatile drive on multiple platforms, including desktops, notebooks and gaming consoles, including PS4, PS3, Xbox One and Xbox 360. Its slim design fits in tight console USB ports, and it lets console users quickly transfer their profiles.
HyperX Savage - USB flash drive - 128 GB
USB flash drive
Interface Type
USB 3.1
Storage Capacity
128 GB
Enclosure Colour
Black, red metallic
Microsoft Windows Vista SP2, Linux 2.6 or later, Microsoft Windows 7 SP1, Windows 8, Apple MacOS X 10.8 or later, Windows 8.1, Windows 10
5-year warranty
USB flash drive
Storage Capacity
128 GB
Enclosure Colour
Black, red metallic
Read Rate
Up to 350 MB/s
Write Rate
Up to 250 MB/s
Interface Type
USB 3.1
Key ring loop
Limited warranty - 5 years
76.3 mm
23.48 mm
12.17 mm
60 °C
