Your basket is empty
Kingston 128GB 2666MHz DDR4 CL15 DIMM (Kit of 8) XMP HyperX Savage Black
Quicklinx: BSX1WS00 Mfr#: HX426C15SBK8/128
Type: DDR4 SDRAM
Capacity: 128GB
Connection: DIMM 288-pin
Speed: 2666MHz
Data Integrity: Non-ECC
22 in stock
£761.32 ex VAT
£913.58 inc VAT
Marketing description is not available.
HyperX Savage - DDR4 - 128 GB : 8 x 16 GB - DIMM 288-pin
RAM memory
128 GB : 8 x 16 GB
Memory Type
DDR4 SDRAM - DIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
Non-ECC
Speed
2666 MHz ( PC4-21300 )
Latency Timings
CL15 ( 15-16-16 )
Dual rank, black heatsink, aluminium heat spreader, On-Die Termination (ODT), Intel Extreme Memory Profiles (XMP), Black PCB, low profile heat spreader, sixteen banks, asymmetrical heatspreader , unbuffered
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty ( Russia - 10 years )
128 GB : 8 x 16 GB
Upgrade Type
Generic
DRAM
DDR4 SDRAM
DIMM 288-pin
Module Height (inch)
1.36
Speed
Latency Timings
CL15 ( 15-16-16 )
Non-ECC
Module Configuration
2048 x 64
Chips Organization
1024 x 8
Voltage
1.2 V
Lead Plating
Gold
RAM Performance
SPD - 2133 MHz - 1.2 V - CL15 - 15-15-15 , Intel Extreme Memory Profiles (XMP) - 2400 MHz - 1.2 V - CL14 - 14-14-14 , Intel Extreme Memory Profiles (XMP) - 2666 MHz - 1.2 V - CL15 - 15-16-16
Colour Category
Kingston 128GB 2666MHz DDR4 CL15 DIMM (Kit of 8) XMP HyperX Savage Black Bundle deal on Kingston 128GB 2666MHz DDR4 CL15 DIMM (Kit of 8) XMP HyperX Savage Black
£777.68
saving £7.75
Type: DDR4 SDRAM
Capacity: 128GB
Speed: 2666MHz
Registered/Buffered: Unbuffered
CAS Latency: CL15
Standard: PC4-21300
Brand: Kingston
Price Range Ex VAT: 750 - 1000
