Kingston 128GB 2400MHz DDR4 ECC CL17 LRDIMM (Kit of 4) 4Rx4
Quicklinx: C54GWS00 Mfr#: KVR24L17Q4K4/128
ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
Kingston ValueRAM - DDR4 - kit - 128 GB: 4 x 32 GB - LRDIMM 288-pin - 2400 MHz / PC4-19200 - LRDIMM with parity
Memory kit
128 GB: 4 x 32 GB
Memory Type
DDR4 SDRAM - LRDIMM 288-pin
Upgrade Type
Generic
Data Integrity Check
ECC
Speed
2400 MHz (PC4-19200)
Latency Timings
CL17 (17-17-17)
Temperature monitoring, quad rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, Load-Reduced with parity
Voltage
1.2 V
Lead Plating
Gold
Limited lifetime warranty (Russia - 10 years)
128 GB: 4 x 32 GB
Upgrade Type
Generic
DRAM memory kit
DDR4 SDRAM
LRDIMM 288-pin
Module Height (inch)
1.23
Speed
Latency Timings
CL17 (17-17-17)
ECC
Module Configuration
4096 x 72
Chips Organization
2048 x 4
Voltage
1.2 V
Lead Plating
Gold
Colour Category
Green
RoHS
