ValueRAM is Kingston's value-priced line of industry-standard, generic memory intended for customers who have white box or generic computer systems, or who plan to purchase memory by specification. ValueRAM is designed to industry specifications tested, is 100% tested and is available at competitively low prices.
- Kingston ValueRAM - DDR4 - kit - 128 GB: 4 x 32 GB - DIMM 288-pin - 2133 MHz / PC4-17000 - registered with parity
- Product Type
- Memory kit
- Capacity
- 128 GB: 4 x 32 GB
- Memory Type
- DDR4 SDRAM - DIMM 288-pin
- Upgrade Type
- Generic
- Data Integrity Check
- ECC
- Speed
- 2133 MHz (PC4-17000)
- Latency Timings
- CL15 (15-15-15)
- Temperature monitoring, dual rank, On-Die Termination (ODT), Serial Presence Detect (SPD), sixteen banks, registered with parity
- Voltage
- 1.2 V
- Lead Plating
- Gold
- Limited lifetime warranty (Russia - 10 years)
- Capacity
- 128 GB: 4 x 32 GB
- Upgrade Type
- Generic
- DRAM memory kit
- Technology
- DDR4 SDRAM
- Form Factor
- DIMM 288-pin
- Speed
- Latency Timings
- CL15 (15-15-15)
- ECC
- Module Configuration
- 4096 x 72
- Chips Organization
- 2048 x 4
- Voltage
- 1.2 V
- Lead Plating
- Gold
- RoHS
