Revive your computer
Get more life out of your computer and maximise your existing investment by replacing your old hard drive with a Kingston® SSDNow V300 solid-state drive. It's the most cost-efficient way to dramatically improve the responsiveness of your system -- and it's less disruptive than migrating your data to a new system.
SSDNow V300 features an LSI® SandForce® controller customised for Kingston and optimised for next-generation Flash memory to deliver the utmost in quality and reliability from two leading SSD brands. Because it's made with solid-state components and has no moving parts, it's shock-proof and withstands drops and bumps.
It's backed by a three-year warranty, free technical support and legendary Kingston reliability.
- Cost-effective system upgrade
- Makes your system more responsive
- Maximises your computer investment
- Faster -- improves speed of loading applications and system boot up
- Reliable -- with no moving parts, solid-state drives are less likely to fail than standard hard drives
- Economical -- design optimised to make migrating to an SSD more affordable
- Form factor -- 2.5-inch drive available in 7.0mm with adapter to fit in 9.5mm systems
- Silent -- cool and silent operation
- Guaranteed -- three-year warranty, free technical support
- Form factor 2.5
- Interface SATA Rev. 3.0 (6Gb/s) - with backwards compatibility to SATA Rev. 2.0
- Capacity 120GB
- Sequential reads2 S ATA Rev. 3.0 up to: 450MB/s
- Sequential writes2 S ATA Rev. 3.0 up to: 450MB/s
- Maximum random 4k read/write
- 120GB -- up to 85,000 / up to 55,000 IOPS
- PCMARK® Vantage HDD Suite score 120GB: 49,000
- Power consumption 0.640 W idle / 1.423 W read / 2.052 W write
- Storage temperatures -40°C~85°C
- Operating temperatures 0°C~70°C
- Dimensions 69.8mm x 100.1mm x 7mm
- Weight 86g
- Vibration operating 2.17G peak (7-800Hz)
- Vibration non-operating 20G peak (10-2000Hz)
- Life expectancy 1 million hours MTBF
- Warranty/support three-year warranty with free technical support
- Total Bytes Written (TBW) 120GB:64TB
See It In Action
Faster
Improves speed of loading applications and system boot up. -
Reliable
With no moving parts, solid-state drives are less likely to fail than traditional hard drives all whilst running silent and cool. -
Economical
Design is optimized to make migrating to an SSD more affordable. -
Convenient
All-in-one kits are available with all the components needed for a fast and easy installation.
- Kingston SSDNow V300 - solid state drive - 120 GB - SATA 6Gb/s
- Solid state drive - internal
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
- Shock resistant, SandForce Driven
- 69.8 mm x 100.1 mm x 7 mm
- 86 g
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Capacity
- 120 GB
- Form Factor
- 2.5"
- Interface
- SATA 6Gb/s
- 69.8 mm
- 100.1 mm
- 7 mm
- 86 g
Performance
- SSD Endurance
- 64 TB
- Drive Transfer Rate
- 600 MBps (external)
- Internal Data Rate
- 450 MBps (read) / 450 MBps (write)
- Maximum 4KB Random Write
- 55000 IOPS
- Maximum 4KB Random Read
- 85000 IOPS
Reliability
- MTBF
- 1,000,000 hours
Expansion & Connectivity
- 1 x SATA 6 Gb/s - 7 pin Serial ATA
- Compatible Bay
- 2.5"
- Power Consumption
- 1.423 Watt (read) , 2.052 Watt (write) , 0.64 Watt (idle)
- ISO 9001:2008, SGS
- Limited warranty - 3 years , Technical support
- 0 °C
- 70 °C
- Vibration Tolerance
- 2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
- Vibration Tolerance (operating)
- 2.17 g @ 7-800 Hz
- Vibration Tolerance (non-operating)
- 20 g @ 10-2000 Hz
StarTech.com Dual 2.5" to 3.5" HDD Bracket for SATA Hard Drives - 2 Drive 2.5" to 3.5" Bracket | In Stock | £7.83 |
StarTech.com USB 3.0 to 2.5" SATA 6GB/s Hard Drive/SSD Adapter Cable | In Stock | £8.75 |
StarTech.com 2.5" to 3.5" SATA Aluminium Hard Drive Adapter Enclosure SSD / HDD Height up to 12.5mm | In Stock | £20.52 |
StarTech.com 2.5in USB 3.0 SATA Hard Drive Enclosure w/ UASP for Slim 7mm SATA III SSD/HDD | In Stock | £17.91 |
