Kingston 120GB SSDNOW UV500 SATA A3 2.5" 6GB/s 256-bit AES Encryption
Quicklinx: DLT9WS00 Mfr#: SUV500/120G
Select:
  • 120 GB
Kingston's UV500 family of solid-state drives dramatically improves the responsiveness of your existing system with incredible boot, loading and transfer times compared to mechanical hard drives. Powered by a Marvell Dean controller combined with 3D NAND Flash for read and write speeds up to 520MB/s and 500MB/s, this SSD is 10X faster than a traditional hard drive for better performance, ultra-responsive multi-tasking and an overall faster system. UV500 provides end-to-end data protection, supports 256-bit AES hardware-based encryption and TCG Opal 2.0 security management solutions. More reliable and durable than a hard drive, UV500 is built with NAND Flash semiconductor memory. There are no moving parts, making it far less likely to fail than a mechanical hard drive. It is also cooler and quieter, and its shock and vibration resistance makes it ideal for notebooks and other mobile computing devices.
Kingston UV500 - SSD - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
Hardware Encryption
Encryption Algorithm
256-bit AES
NAND Flash Memory Type
3D triple-level cell (TLC)
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
End-to-end data protection, Marvell 88SS1074 controller
69.85 mm x 100.1 mm x 7 mm
41 g
5-year warranty
120 GB
Hardware Encryption
256-bit AES
2.5"
SATA 6Gb/s
69.85 mm
100.1 mm
7 mm
41 g
Performance
SSD Endurance
60 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
520 MBps (read) / 320 MBps (write)
Maximum 4KB Random Write
18000 IOPS
Maximum 4KB Random Read
79000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5"
Power Consumption
0.5 Watt (average) , 0.195 Watt (idle) , 1.17 Watt (read) , 2.32 Watt (write)
Limited warranty - 5 years , Technical support
70 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
85 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
