Product
Brand
Kingston 120GB SSDNow UV400 2.5" SATA 6Gb/s SSD Upgrade Kit
Quicklinx: C3MSWS00 Mfr#: SUV400S3B7A/120G
Form Factor: 2.5"
Capacity: 120GB
Interface: Serial ATA-600
Type: Internal hard drive
Stock Status: Clearance
34 left in stock
£40.20 ex VAT
£48.24 inc VAT
Express delivery Order within the next 19 hours for delivery on Thursday
Kingston's SSD UV400 is powered by a four-channel Marvell controller for amazing speeds and higher performance. It dramatically improves the responsiveness of your existing system. Rugged and more reliable and durable, UV400 is built using flash memory so it's shock- and vibration-resistant and less likely to fail than a mechanical hard drive. Its ruggedness makes it ideal for notebooks and other mobile computing devices. It's the ideal hard drive replacement and can also replace a smaller SSD in your system to give you all the room you need.
Kingston UV400 Desktop/Notebook Upgrade Kit - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
NAND Flash Memory Type
Triple-level cell (TLC)
2.5" (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
Shock resistant, rugged, Marvell 88SS1074 controller
69.9 mm x 100 mm x 7 mm
57 g
3 years warranty
120 GB
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
57 g
Performance
SSD Endurance
50 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 350 MBps (write)
Maximum 4KB Random Write
15000 IOPS
Maximum 4KB Random Read
90000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" or 3.5" (with included bay adapter)
Power Consumption
0.693 Watt (average) , 0.672 Watt (idle) , 0.59 Watt (read) , 2.515 Watt (write)
3.5-inch bay adapter, 2.5" USB enclosure, 7mm to 9.5mm holder
1 x Serial ATA cable - internal
Mounting Kit
Included
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
Form Factor: 2.5"
Capacity: 120GB
Brand: Kingston
Price Range Ex VAT: 0 - 50
