Your basket is empty
Kingston 120GB SSDNow KC380 SATA 6GB/s 1.8" Solid State Drive
Quicklinx: 8XNTWS00 Mfr#: SKC380S3/120G
Form Factor: 1.8"
Capacity: 120GB
Interface: Serial ATA-600
Type: Internal hard drive
Stock Status: Clearance
More than 50 in stock
£82.49 ex VAT
£98.98 inc VAT
Kingston's KC380 SSDNow solid-state drive features a small case form factor that fits in notebooks, sub-notebooks, tablet PCs and netbooks with a smaller physical device storage footprint. Lighter than a traditional hard drive, it lets users take advantage of the durability, reliability and performance improvements of Flash memory in systems currently using 1.8" hard drives and is the ultimate hard drive replacement.
KC380 consumes less power and generates less heat than a traditional HDD - at a fraction of the cost of a new system. It offers advanced data integrity protection and a SandForce second-generation SSD processor with DuraClass technology. DuraClass features include DuraWrite and advanced wear-leveling to extend the life of the drive and garbage collection and over-provisioning for consistent performance and a longer life for your SSD and your data.
Kingston SSDNow KC380 - solid state drive - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
1.8"
SATA 6Gb/s
Data Transfer Rate
600 MBps
TRIM support, DuraClass technology, SandForce Driven, DuraWrite technology, Garbage Collection technology, Wear Leveling Support, SandForce SF-2241 controller, S.M.A.R.T.
54 mm x 78.5 mm x 5 mm
27.43 g
3 years warranty
120 GB
1.8"
SATA 6Gb/s
54 mm
78.5 mm
5 mm
27.43 g
Performance
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
550 MBps (read) / 520 MBps (write)
4KB Random Read
17000 IOPS
4KB Random Write
45000 IOPS
Maximum 4KB Random Write
48000 IOPS
Maximum 4KB Random Read
86000 IOPS
Reliability
MTBF
1,000,000 hours
Expansion & Connectivity
1 x SATA 6 Gb/s - 16 pin Micro Serial ATA
Compatible Bay
1.8"
Power Consumption
1.8 Watt (active) , 0.4 Watt (idle)
Limited warranty - 3 years , Technical support
70 °C
Vibration Tolerance
2.17 g @ 7-800 Hz (operating) / 20 g @ 10-2000 Hz (non-operating)
Kingston 120GB SSDNow KC380 SATA 6GB/s 1.8 Bundle deal on Kingston 120GB SSDNow KC380 SATA 6GB/s 1.8" Solid State Drive
Including:
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £6.01 | in stock
£85.50
saving £3.01
Including:
£85.50
saving £3.01
Form Factor: 1.8"
Capacity: 120GB
Brand: Kingston
Price Range Ex VAT: 50 - 100
