HyperX Kingston 120GB HyperX Savage SSD SATA 3 2.5"
Quicklinx: B7ZZWS00 Mfr#: SHSS37A/120G
HyperX Savage solid-state drive offers extreme performance for the extreme performer. The fastest HyperX SATA-based SSD, it's powered by a quad-core, 8-channel Phison S10 controller that delivers incredible speeds of up to 560 MB/s read and 530 MB/s write, with read/write IOPS up to 100k/89k.
The result is ultra-responsive multitasking and an overall faster system that maintains performance even as the drive fills up. With its low profile and slim, 7mm form factor, HyperX Savage SSD fits in most notebooks, desktops and HTPC builds.
HyperX Savage - SSD - 120 GB - SATA 6Gb/s
Solid state drive - internal
120 GB
2.5" (in 3.5" carrier)
SATA 6Gb/s
Data Transfer Rate
600 MBps
Phison PS3110-S10 controller
69.9 mm x 100 mm x 7 mm
96 g
3-year warranty
120 GB
2.5"
SATA 6Gb/s
69.9 mm
100 mm
7 mm
96 g
Performance
Drive Writes Per Day (DWPD)
0.89
SSD Endurance
113 TB
Drive Transfer Rate
600 MBps (external)
Internal Data Rate
560 MBps (read) / 360 MBps (write)
4KB Random Read
93000 IOPS
4KB Random Write
83000 IOPS
Maximum 4KB Random Write
84000 IOPS
Maximum 4KB Random Read
100000 IOPS
Reliability
MTBF
1,000,000 hour(s)
Expansion & Connectivity
1 x SATA 6 Gb/s - 7 pin Serial ATA
Compatible Bay
2.5" or 3.5" (with included bay adapter)
Power Consumption
1.4 Watt (read) , 4.35 Watt (write) , 0.39 Watt (idle) , 0.5 Watt (average)
3.5-inch bay adapter, 7mm to 9.5mm holder
Mounting Kit
Included
ISO 9001:2008, SGS
Limited warranty - 3 years
70 °C
Vibration Tolerance (operating)
2.17 g @ 7-800 Hz
Vibration Tolerance (non-operating)
20 g @ 10-2000 Hz
