Kinesis Advantage Pro Keyboard - US
Quicklinx: B0CDWS00 Mfr#: KIN-ADVPRO
The thumb keypad includes often used keys such as Enter, Space, Backspace, Delete and the combination keys, Control and Alt on the PC. This redistributes the workload from your relatively weaker and overused little fingers to stronger thumbs.
This separation minimizes strain and stretching by positioning your arms approximately at shoulder width and with wrists straight. This design reduces abduction and ulnar deviation (common symptoms experienced with repetitive strain injuries such as carpal tunnel syndrome and tendonitis).
  • Separate thumb keypads
  • Separate key wells for each hand
Kinesis Advantage Pro - keyboard - US - metallic
Keyboard - ergonomic (contoured)
USB
Wired
Localization and Layout
US
Hot Keys Function
Macros buttons
2-port USB hub, MPC technology
Metallic
41.9 cm x 20.3 cm x 7.6 cm
USB
Input Device
Hot Keys Function
Macros buttons
US
41.9 cm
20.3 cm
7.6 cm
2 x USB
Metallic
Palm Pads
