KGUARD Security Aurora Series Combo Kit AR421-CKT001 - DVR + Camera(s)
Quicklinx: 9PYYWS00 Mfr#: AR421-CKT001
The Aurora Series DVR has a wide range of features, including push notification, front panel touch technology, easy connection via a QR code, 960H recording resolution, HDMI output and cloud storage as well as access to the"MyKGUARD"homepage. KGUARD has designed all these functions with the latest technologies into its DVR in order to satisfy our customers' needs.
The new series is equipped with both 800TVL and 700 TVL high resolution cameras. The 800TVL auto tracking camera allows you to focus on moving objects. The camera can automatically detect moving objects in its field of view and focus on that part of the picture to make it become larger and clearer. Also included is the WDR, which filters out the intense back light and eliminates shadows.
KGuard Aurora Series Combo Kit AR421-CKT001 - DVR + camera(s)
System
DVR + camera(s)
Security DVR
4 channels
Camera
4 cameras - outdoor - NTSC/PAL - night vision
1 year
System
DVR + camera(s)
Package Content
4 cameras, DVR, manual, remote control, mouse, power adapter
HDMI cable - 1 pcs. , Network cable - 1 pcs. , Video / power cable - 4 pcs.
Software Included (Y)
Drivers & Utilities
Warranty
1 year
Security DVR
Video Channels
4
Frame Rate (Playback)
200 fps (PAL), 240 fps (NTSC)
Frame Rate (Record)
120 fps (PAL), 100 fps (PAL)
Image Resolution
704x480 (NTSC), 704x576 (PAL), 352x240 (NTSC), 352x288 (PAL), 704x240 (NTSC), 704x288 (PAL), 960x576 (PAL), 960x480 (NTSC), 960x240 (NTSC), 960x288 (PAL), 480x240 (NTSC), 480x288 (PAL)
Compression Format
H.264
Record Events
Alarm, motion detection, scheduled, manual
Motion detection
Hard Drive
Quantity Supported
1
Serial ATA
Supported Max Total Capacity
2 TB
Cameras
Quantity
4 cameras
Camera Type
Outdoor
TV System
NTSC/PAL
Sensitivity (lux)
0
Night Vision
Focal Length
3.6 mm
-10 °C
50 °C
Video Input Ports
BNC x 4
Video Output Ports
HDMI x 1, BNC x 1, VGA x 1
Audio Input Ports
RCA x 4
Audio Output Ports
RCA x 1
Camera Control Interface (PTZ)
RS-485
Network Port
10/100Base-T
Details
DVR: 31.5 cm x 23 cm x 4 cm , Camera: 7.2 cm x 16.75 cm x 6.3 cm - 300 g , Camera: 5.8 cm x 16.4 cm x 5.8 cm - 295 g
