The Kensington Wall Laptop Power Adapter is ideal whether you're looking for a replacement or a secondary power adapter at home or on the move. It provides the reliability that you need and is compatible with a wide range of laptops from leading manufacturers.
- Kensington Wall Laptop Power Adapter - power adapter - 90 Watt
- Power adapter - external
- 320 g
- Localisation
- Europe
- Power Capacity
- 90 Watt
- Black
- 5.2 cm x 13.1 cm x 2.8 cm
- Environmental Standards
- ENERGY STAR
- 2-year warranty
- Black
- Localisation
- Europe
- Power Capacity
- 90 Watt
- Cables Included
- Power cable
- Overheat protection, over current protection, over voltage protection, short-circuit protection
Sustainability Information
- ENERGY STAR
- Limited warranty - 2 years
- 5.2 cm
- 13.1 cm
- 2.8 cm
- 320 g
