With more and more people realizing the productivity gains of working on a 4K monitor, Kensington has an easy way for you to upgrade your laptop without the need for a 4K graphics card. The VU4000 4K Video Adapter simply plugs into a USB 3.0 port on your laptop and goes into the HMDI port on a monitor, projector or TV so you can see your content in Ultra HD. You can either mirror your laptop screen or extend it for increased productivity.
Enables 4K resolution
Quickly and easily display in Ultra HD from your laptop to a 4K monitor, TV or projector without the need for a 4K graphics card. -
Universal connection
Connect your system to the HDMI cable for your 4K monitor or TV via the USB 3.0 port found on virtually all laptops and desktops. -
Extend or mirror options
Maximize your productivity by adding a 2nd screen or putting your laptop screen on a large monitor. -
Plug & Play installation
Simply plug in the adapter and everything takes care of itself with the driver automatically downloading and installing.
- Kensington VU4000 4K Video Adapter - external video adapter - black
- External video adapter
- Bus Type
- SuperSpeed USB 3.0
- Interfaces Details
- HDMI
- Enclosure Colour
- Black
- 2-year warranty
- Bus Type
- HDMI
- OS Required
- Microsoft Windows 7 / 8 / 8.1
- Plug and Play
- Enclosure Colour
- Black
- Limited warranty - 2 years
