Product
Kensington VM1000 Mini Display Port to VGA Adapter
Quicklinx: BZ7KWS00 Mfr#: K33987WW
5 in stock
£14.46 ex VAT
£17.35 inc VAT
Standard delivery Delivered within 3-5 working days
When you need to put whats on your laptop screen on a monitor or a projector, theres no easier way than with the VM1000 Video Adapter. It plugs into Mini DisplayPort commonly found on laptops and then runs to the VGA port on a monitor or projector. The adapter supports full HD resolution so you get a crystal clear picture and offers Plug & Play installation so youre up and running in no time.
Kensington VM1000 Mini DisplayPort to VGA Adapter - video converter - black
Video converter
Max Resolution
1920 x 1200
1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DisplayPort input - Mini DisplayPort
2.5 cm x 1.3 cm x 27.9 cm
Enclosure Colour
2 years warranty
Video converter
Max Resolution
1920 x 1200
1 x VGA output - 15 pin HD D-Sub (HD-15) - female , 1 x DisplayPort input - Mini DisplayPort - male
Apple MacOS X 10.6, Apple MacOS X 10.7 Lion, Apple MacOS X 10.8, Microsoft Windows 7 / 8 / 10, Apple MacOS X 10.11
Plug and Play
2.5 cm
1.3 cm
27.9 cm
Enclosure Colour
Brand: Kensington
Price Range Ex VAT: 0 - 50
