Kensington VESA Mount Plate for Kensington SD3600 USB 3.0 Dual-Dock
Quicklinx: BZ89WS00 Mfr#: K33959WW
£10.14 ex VAT
£12.16 inc VAT
If youre incorporating a Kensington Docking Station into your system, such as the SD3600, but you have limited desktop space, the Docking Station Mounting Plate is the ideal complement. It allows you to mount the dock on the back of your VESA-compatible monitor even if its attached to a monitor arm. The mounting plate also has special slots that let you adjust the placement of the dock to your preferred location.
  • Zero desktop footprint
    Designed to allow you to remove the docking station from your desktop, freeing up space so you can better utilize the space for other accessories or just leave the desktop uncluttered.
  • VESA compatible
    Easily mount the dock to the backside of your monitor, whether it's on a stand or attached to a monitor arm. Compatible with 75mm or 100mm VESA hole layouts in either an up-down or left-right orientation.
  • Adjustable placement
    Specially designed slots in the mounting plate allow you to slide the docking station to your preferred position before tightening it into place.
Kensington mounting component - for docking station - black
Mounting component
Mounting Components
Mounting plate
Recommended Use
Docking station
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Material
Metal
Material
Metal
AV Furniture
Mounting component
Mounting Components
Mounting plate
Recommended Use
Docking station
Brand: Kensington
