Not all 9-inch and 10-inch tablets are made to the same specifications. A half-inch there or there and your tablet wont fit into a case. Kensington has solved that problem with a universal case that features a contemporary cover design and can hold all the most popular 9-inch and 10-inch tablets. The soft, lightweight case offers secure protection for your device through the Silicone 4-Corner Base, which uses stay straps that come up and over the corners of the tablet. The inside cover has soft lining that prevents the screen from getting scratched or damaged and a magnetic flap keeps the case securely closed. The cover can be opened or folded into an upright or low-angle triangle stand so you can select the ideal position for watching videos, typing emails or web browsing.
Universal fit
Designed to securely hold a wide variety of tablets from the most popular brand names. -
Silicone 4-corner base
Stay straps come up and over the corners of the tablet to securely hold it in place. -
Soft interior lining
Protects your tablet's delicate screen from scratches and damage. -
Multi-position stand
The cover also can be opened or folded into an upright or low-angle triangle stand, allowing you to select the ideal position for hands-free video viewing, typing E-mails or web browsing. -
Magnetic flap
Ensures the case is closed securely, maintaining worry-free mobility for you and your tablet.
- Kensington Universal - flip cover for tablet
- Product Type
- Flip cover for tablet
- Screen Size Compatibility
- 10"
- Black
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- 10"
- Protection
- Scratch-resistant
- Cover Type
- Flip cover
- Closure Type
- Magnetic closure
- Adjustable viewing angles, soft inner lining
- Cover Features
- Stand function
