Kensington Universal Case for 10'' Tablets - Black
Quicklinx: CRKYWS00 Mfr#: K97328WW
Not all 9-inch and 10-inch tablets are made to the same specifications. A half-inch there or there and your tablet wont fit into a case. Kensington has solved that problem with a universal case that features a contemporary cover design and can hold all the most popular 9-inch and 10-inch tablets. The soft, lightweight case offers secure protection for your device through the Silicone 4-Corner Base, which uses stay straps that come up and over the corners of the tablet. The inside cover has soft lining that prevents the screen from getting scratched or damaged and a magnetic flap keeps the case securely closed. The cover can be opened or folded into an upright or low-angle triangle stand so you can select the ideal position for watching videos, typing emails or web browsing.
  • Universal fit
    Designed to securely hold a wide variety of tablets from the most popular brand names.
  • Silicone 4-corner base
    Stay straps come up and over the corners of the tablet to securely hold it in place.
  • Soft interior lining
    Protects your tablet's delicate screen from scratches and damage.
  • Multi-position stand
    The cover also can be opened or folded into an upright or low-angle triangle stand, allowing you to select the ideal position for hands-free video viewing, typing E-mails or web browsing.
  • Magnetic flap
    Ensures the case is closed securely, maintaining worry-free mobility for you and your tablet.
Kensington Universal - flip cover for tablet
Flip cover for tablet
Screen Size Compatibility
10"
Carrying Case
Protective cover
Recommended Use
For tablet
10"
Protection
Scratch-resistant
Cover Type
Flip cover
Closure Type
Magnetic closure
Adjustable viewing angles, soft inner lining
Cover Features
Stand function
