Kensington Ultra MicroSaver2.0 Keyed Lock
Quicklinx: CRLDWS00 Mfr#: K64432WW
£39.68 ex VAT
£47.61 inc VAT
Engineered to be s small lock for laptops and other devices with no compromises, the MicroSaver 2.0 represents the next generation of laptop security with a cable that's stronger than the standard model. The MicroSaver 2.0 was developed using strict specifications and advanced technologies in a smaller, compact size.
  • Strong lock heads
    The lock head is designed for even thin laptops and devices while still meeting Kensington's standards for tamper-resistance, reliability and durability.
  • T-Bar locking technology
    The rotating bar securely attaches to the internal wall of the device for a premium level of security.
  • Ultra carbon steel cable
    The thicker cable is stronger than a standard cable, made of woven carbon steel and covered by an anti-shearing sleeve for the high level of protection against cutting attempts.
  • Pivot and rotate cable
    Special hinge creates great freedom of movement, eliminating awkward angles and allowing you to insert your key with complete ease.
Kensington MicroSaver 2.0 Keyed Ultra Laptop Lock - security cable
Security cable
Silver
Product Material
Carbon steel
T- bar lock, pivot adjustment, cut-resistant, hidden pin, rotatable
Security cable
Product Material
Carbon steel
Silver
