Kensington UH4000C USB 3.0 4-Port Hub & Charger - Black
Quicklinx: BZ79WS00 Mfr#: K33979EU
With USB ports on laptops becoming a precious commodity, an external hub can be the answer to maintaining optimal productivity. The UH4000C USB 3.0 4-Port Hub & Charger ensures you can connect all your peripheral desktop accessories to your laptop, as well as quickly charge your smartphone or tablet. Leveraging USB 3.0 technology, each of the four ports can support lightning fast transfer speeds so you can work more efficiently. The ports also double as chargers, ensuring the battery on your favorite devices never runs out. With 3 AMPs available, you can use any of the ports to provide a fast charge for a tablet and a smartphone, or other combination of low power devices. Because there are no drivers to download, simply insert the USB cable it into your laptop, plug in the power cord, and you're ready to go.
  • 4 USB 3.0 charge and sync ports
    Expand your device's productivity capabilities by plugging your peripheral accessories into any of four USB 3.0 ports and then watch the battery on your smartphones and/or tablets charge up in the process with the available 3 AMPs of power.
  • Lightning fast transfer speeds
    Using USB 3.0 technology, the hub supports transfer speeds up to 5 Gbps, which is 10 times faster than USB 2.0.
  • Plug & play operation
    Simply insert the USB cable on the hub into your device and it's automatically ready to go with no need for a driver download.
  • Near universal acceptance
    The adapter is compatible with devices running Windows 8.1/8/7/Vista/XP; Mac OS X 10.6 or later operating systems.
Kensington UH4000C - hub - 4 ports
Hub - 4 ports
Subtype
USB
Ports
4 x SuperSpeed USB 3.0
USB 1.1, USB 2.0, USB 3.0
7.5 cm x 5.1 cm x 1.45 cm
38 g
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Europe
Hub - 4 ports
Enclosure Type
Desktop
Subtype
USB
Ports
4 x USB 3.0 Type A
Plug and Play, BC1.2
Europe
7.5 cm
5.1 cm
1.45 cm
38 g
