Your basket is empty
Kensington UA3000E USB 3.0 Ethernet Adapter & 3-Port Hub - Black
Quicklinx: BZ7FWS00 Mfr#: K33982WW
Wired / Wireless: Wired
Protocol: Gigabit Ethernet
Compatibility: PC
Type: Network adapter
8 in stock
£40.10 ex VAT
£48.12 inc VAT
Standard delivery Delivered within 3-5 working days
Many newer laptops do not come with an Ethernet port, leaving users only WiFi to get connected to the Internet. The UA3000E USB 3.0 Ethernet Adapter & 3-Port Hub provides a wired connectivity option with lightning fast transfer speeds where wireless access isnt available or if you have a broken internal network card. The USB 3.0 Ethernet adapter simply plugs into an available port on your laptop and supports 10/100/1000 BASE-T performance. Also included are three USB 3.0 ports for additional device expansion. The adapter is compatible with systems running Windows 8.1/8/7/Vista/XP, as well as Mac OS X 10.6 and later.
Kensington UA3000E - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet x 1 + USB 3.0 x 3
10.5 cm x 4.5 cm x 2.4 cm
68 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
USB 2.0, USB 3.0
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
USB 2.0, USB 3.0
1 x 1000Base-T - RJ-45 , 3 x USB 3.0 - 9 pin USB Type A
Plug and Play
10.5 cm
4.5 cm
2.4 cm
68 g
BZ7F C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £4.26
BZ7F C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.24
BZ7F C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.42
BZ7F C2G 2m Cat6a Shielded Patch - Blue In Stock £7.44
BZ7F C2G TruLink Media Gateway RJ45 Cap In Stock £0.58
BZ7F C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £47.13
Compatibility: PC
Brand: Kensington
Price Range Ex VAT: 0 - 50
