Kensington UA0000E USB 3.0 Ethernet Adapter - Black
Quicklinx: BZ7DWS00 Mfr#: K33981WW
Wired / Wireless: Wired
Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet
Compatibility: Mac, PC
Type: Network adapter
30 in stock
£17.05 ex VAT
£20.46 inc VAT
Many newer laptops do not come with an Ethernet port, leaving users only WiFi to get connected to the Internet. The UA0000E USB 3.0 Ethernet Adapter provides a wired connectivity option with lightning fast transfer speeds where wireless access isnt available or if you have a broken internal network card. The USB 3.0 Ethernet adapter simply plugs into an available port on your laptop or desktop computer and supports 10/100/1000 BASE-T performance. The adapter is compatible with systems running Windows 8.1/8/7/Vista/XP, as well as Mac OS X 10.6 and later.
Kensington UA0000E - network adapter
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet x 1
7.6 cm x 2.4 cm x 1.5 cm
26 g
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, GigE
Data Transfer Rate
1 Gbps
USB 2.0, USB 3.0
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8 / 8.1
Network adapter
External
SuperSpeed USB 3.0
Ports
Wired
Cabling Type
Data Transfer Rate
1 Gbps
USB 2.0, USB 3.0
1 x 1000Base-T - RJ-45 - female
Plug and Play
7.6 cm
2.4 cm
1.5 cm
26 g
Protocol: Ethernet
Protocol: Fast Ethernet
Protocol: Gigabit Ethernet
Compatibility: Mac
Compatibility: PC
Brand: Kensington
Price Range Ex VAT: 0 - 50
