Improve posture, promote healthy circulation and support back and leg comfort with the SmartFit SoleMate Pro Elite ergonomic foot rest. Ergonomically designed to promote wellness and support increased productivity, the SmartFit SoleMate Pro Elite ergonomic foot rest incorporates Kensington's patented SmartFit technology to simplify proper fit and allows users to adjust the height and angle for customised comfort. An ideal foot rest for modern home office or hot-desking environments.
Ergonomic design
The Kensington SoleMate Pro Elite foot-rest is engineered with an ergonomic design to enhance comfort and support. Its adjustable angle and height features allow for a personalized setup, ensuring optimal positioning for long hours at the desk. -
Stable and secure
Featuring an anti-slip base and lockable adjustments, the SoleMate Pro Elite offers a stable and secure platform. The tilt adjustment further enhances its functionality, allowing users to find the perfect angle for their comfort. -
Durable construction
Constructed from high impact polystyrene (HIPS) and carpet, this foot-rest is designed for durability. It withstands the rigors of daily use, providing reliable support and comfort.
- Kensington SoleMate Pro Elite - foot-rest
- Product Type
- Foot-rest
- Grey
- Product Material
- Carpet, high impact polystyrene (HIPS)
- 53 cm x 34 cm x 9 cm
- 2.3 kg
- Tilt adjustment, lockable, adjustable height, SmartFit, adjustable angle, anti-slip base
- 2-year warranty
- Product Type
- Foot-rest
- Product Material
- 53 cm
- 34 cm
- 9 cm
- 2.3 kg
- Grey
- Limited warranty: - 2 years
