Monitor Stand Plus with the SmartFit system adjusts monitor height to your optimal viewing angle to help to reduce eye and neck strain. Expands usable desk space by allowing storage underneath platform.
- Kensington SmartFit Plus stand - for Monitor - grey, black
- Product Type
- Stand - desktop
- 39.4 cm x 30.5 cm x 14 cm
- Adjustments
- Recommended Use
- Monitor
- Recommended Display Size
- 21"
- Max Load Weight
- 36.3 kg
- Grey, black
- 3-year warranty
- 39.4 cm
- 30.5 cm
- 14 cm
- Grey, black
AV Furniture
- Stand
- Recommended Use
- Monitor
- Placing / Mounting
- Desktop
- 21"
- Adjustments
- Max Load Weight
- 36.3 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 32.2 cm x 41.3 cm x 5.6 cm / 2.12 kg
- Limited warranty - 3 years
