Monitor Stand Plus with the SmartFit system adjusts monitor height to your optimal viewing angle to help to reduce eye and neck strain. Expands usable desk space by allowing storage underneath platform.
- Kensington SmartFit Plus - stand
- Product Type
- Stand - desktop
- 39.4 cm x 30.5 cm x 14 cm
- Adjustments
- Recommended Use
- LCD display
- Recommended Display Size
- 21"
- Max Load Weight
- 36.3 kg
- Grey, black
- 3 years warranty
- 39.4 cm
- 30.5 cm
- 14 cm
- Grey, black
AV Furniture
- Stand
- Recommended Use
- LCD display
- Placing / Mounting
- Desktop
- 21"
- Adjustments
- Max Load Weight
- 36.3 kg
Dimensions & Weight Details
- Shipping Dimensions (WxDxH) / Weight
- 32.2 cm x 41.3 cm x 5.6 cm / 2.12 kg
- Limited warranty - 3 years
