Your basket is empty
Kensington SmartFit Laptop Riser - Notebook stand - 15.6" -
Quicklinx: CMLCWS00 Mfr#: K52783WW
£40.85 ex VAT
£49.02 inc VAT
When you need to lift your laptop up to eye level, theres no better ergonomic solution than the SmartFit Laptop Riser. Kensington has been a leader in ergonomics for more than 20 years and the laptop riser features the SmartFit System, which allows you to find your personal height setting for optimal comfort to reduce neck and back strain while you work. It also utilizes Zero Footprint mounting so you can mount a compatible Kensington universal dock underneath the laptop platform, keeping your desktop less cluttered.
Kensington SmartFit Laptop Riser - notebook stand
Notebook stand
Notebook Compatibility
15.6"
Adjustable height, integrated cable management, anti-skid grip, SmartFit, kensington security slot, Zero Footprint Mounting
Notebook stand
15.6"
Weight Limit
3.49 kg
Brand: Kensington
Price Range Ex VAT: 0 - 50
