Kensington TrackballWorks
idea: Your trackball, your rules.
Download Kensington TrackballWorks software to customise the functions of each of the buttons found on this Kensington trackball. The result is a more productive and truly personalized computing experience. Set your preferred functions or keyboard shortcuts for each trackball button or combination of buttons, adjust the pointer speed and acceleration and do so much more. Best of all, by allowing you to personalise your trackball experience, TrackballWorks makes your trackball work the way you do. TrackballWorks is compatible with the latest operating system versions including Windows 7, Windows Vista , Windows XP and Mac OS.
- Kensington SlimBlade Trackball - trackball - USB - graphite, Ruby Red
- Trackball
- Connectivity Technology
- Wired - USB
- Graphite, Ruby Red
- Localisation
- Europe
- Cables Included
- 1 x USB cable - integrated
- OS Required
- Apple MacOS X, Microsoft Windows Vista / XP
- Microsoft Certification
- Compatible with Windows 7
- 5 years warranty
- Trackball
- Localisation
- Europe
Input Device
- Wired
- Interface
- USB
- 1 x USB - 4 pin USB Type A
- Cables Included
- USB 2.0
- OS Required
- Limited warranty - 5 years
