Kensington Slimblade Trackball
Quicklinx: 6ND6WS00 Mfr#: K72327EU
Recommended Use: Office
Type: Trackball
Wired / Wireless: Wired
Colour: Graphite, Ruby Red
Compatibility: Mac, PC
Hurry, only 3 left in stock!
£77.21 ex VAT
£92.65 inc VAT
Kensington TrackballWorks
idea: Your trackball, your rules.
Download Kensington TrackballWorks software to customise the functions of each of the buttons found on this Kensington trackball. The result is a more productive and truly personalized computing experience. Set your preferred functions or keyboard shortcuts for each trackball button or combination of buttons, adjust the pointer speed and acceleration and do so much more. Best of all, by allowing you to personalise your trackball experience, TrackballWorks makes your trackball work the way you do. TrackballWorks is compatible with the latest operating system versions including Windows 7, Windows Vista , Windows XP and Mac OS.
Kensington SlimBlade Trackball - trackball - USB - graphite, Ruby Red
Trackball
Wired - USB
Graphite, Ruby Red
Europe
1 x USB cable - integrated
Apple MacOS X, Microsoft Windows Vista / XP
Microsoft Certification
Compatible with Windows 7
5-year warranty
Trackball
Graphite, Ruby Red
Europe
Input Device
Wired
USB
1 x USB - 4 pin USB Type A
USB 2.0
Limited warranty - 5 years
Type: Trackball
Colour: Graphite
Colour: Ruby Red
Compatibility: Mac
Compatibility: PC
Brand: Kensington
Price Range Ex VAT: 50 - 100
