Kensington SecureBack Enclosure for iPad Air 1/2
Quicklinx: CRLQWS00 Mfr#: K67772WW
Protect your iPad from just about anything with a Kensington BlackBelt 3rd degree Rugged Case for iPad Air. The BlackBelt 3rd degree utilizes dual layer construction, providing the maximum level of protection, absorbing shocks and preventing damage. The vulnerable corners of your iPad receive extra protection and the raised bezel shelters the retina display from potential scratches. Theres a built-in ClickSafe anchor that makes it easy to protect the iPad against theft, as well. Simply click on a ClickSafe lock (sold separately) and your iPad is secure, with no keys and no fiddling. Some threats to your iPad are big, such as drops and theft. Others are tiny: dust. The fact is, dust can do real damage to the sensitive electronics in your iPad. Fortunately, the BlackBelt 3rd degree protects against dust as well thanks to its built-in port covers. Maybe best of all, BlackBelt 3rd Degree is expandable accessories designed for SecureBack M Series are compatible with BlackBelt 3rd Degree. Need to hold your iPad for lengthy periods of time? Simply attach the Hand Strap for SecureBack M Series (K67832WW, sold separately). Need a robust Kick Stand, attach the Kick Stand for SecureBack M Series (K67786WW, sold separately).
But despite all of this protection, the BlackBelt 3rd Degree preserves access to all ports and controls. So protect your iPad with the ultimate protection against damage from drops and bumps the Kensington BlackBelt 3rd degree Rugged Case for iPad Air.
  • Sleek protection
    Preserves the thin, lightweight design aesthetics of the iPad Air or the iPad Air 2 while adding both anti-theft security and protection against bumps and drops.
  • Power cord management
    Allows for either pass-through or enclosed routing options that reduce clutter at the workstation.
  • Compatible with 75mm VESA Mounts
    Holes in the back of the enclosure make for a quick and easy installation and mounting to stands, and screws are included.
Kensington SecureBack Enclosure - back cover for tablet
Back cover for tablet
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Back cover
Cord management system, clear screen protector, ClickSafe Security Anchor, button covers, VESA 75x75
2 years
