Kensington SD4700P Universal USB-C Dock
Quicklinx: DDDDWS00 Mfr#: K38240EU
Supporting the advanced USB-C connections, and legacy computers with USB 3.0 ports, the SD4700P Universal USB-C and USB 3.0 Docking Station is the ideal docking solution for evolving computer environments. Engineered using stable technology, the SD4700P provides compatibility that just works. The SD4700P extends the life of your technology investments and is easy and painless to setup.
Kensington SD4700P USB-C and USB 3.0 Dock - docking station - USB-C / USB 3.0 - HDMI, DP - 1GbE
Docking station
Docking Interface
USB-C / USB 3.0
Video Interfaces
HDMI, DP
20 cm x 9.12 cm x 3.05 cm
1.13 kg
Europe
Gigabit Ethernet
Power adapter AC 120/230 V / DC 20 V (50/60 Hz) 135 Watt Power Provided
Pricing Type
Brown Box
3-year warranty
Docking station
20 cm
9.12 cm
3.05 cm
1.13 kg
Enclosure Colour
Europe
1 x display / video - DisplayPort - 20 pin DisplayPort , 1 x display / video - HDMI - 19 pin HDMI Type A , 5 x SuperSpeed USB 3.0 - 9 pin USB Type A , 2 x USB-C - 24 pin USB-C , 1 x audio - headphones/microphone - mini-phone stereo 3.5 mm , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45
1 x USB-C cable - external - 1 m , 1 x USB-C to USB 3.0 adapter - external
Security lock slot (cable lock sold separately), VESA interface support, 1 USB 3.0 fast charging port, Zero Footprint Mounting
Security Slot Type
Kensington security slot
Plug and Play, FCC, RoHS, WEEE, REACH, RCM
Pricing Type
Brown Box
Power adapter
Power Provided
135 Watt
Microsoft Windows 7 / 10, Apple macOS 10.13 or later
Limited warranty - 3 years
