Kensington SD3650 USB 3.0 Dual Dock DP/HDMI
Quicklinx: CRJ9WS00 Mfr#: K33997WW
More than 50 in stock
£119.34 ex VAT
£143.20 inc VAT
Preserve the convenience of one-cable connectivity to your entire desktop setup with the SD3650 Universal USB 3.0 Docking Station from Kensington, a trusted leader in productivity solutions for more than 30 years. What makes the SD3650 unique from the SD3600 is that you can output dual HD video using DisplayPort and HDMI ports, plus we increased the USB 3.0 accessory expansion ports to four, ideal for a flash drive so it can transfer data at 5Gbps. The dock also features Zero Footprint Mounting, so it can be mounted to the back of a VESA-compatible monitor using a Docking Station Mount (sold separately), perfect for desks with limited space.
  • Dual HD video output
    With DisplayPort and HDMI ports, you can expand your workspace and increase productivity by adding 2 external screens.
  • Zero footprint mounting
    The dock can be mounted to the back of a 75mm or 100mm VESA-compatible external monitor, allowing you to keep your desktop less cluttered
  • 4 USB 3.0 ports
    Transfer data at up to 5Gbps with the fast and powerful ports, two of which are on the front of the dock, the other two are in the back. One of the front ports doubles as a 2.1A fast charge port that can power a smartphone or tablet.
  • 2 rear USB 2.0 ports
    The ideal place to plug in accessories like a keyboard or mouse to help keep cables or wireless receivers hidden from view
  • Extend or mirror modes
    Extend mode allows you to drag an open application to an external monitor so you can work across multiple screens, while Mirror mode allows you to replicate the content that's on your computer display to an external screen
Kensington SD3650 5Gbps USB 3.0 Dual 2K Docking Station DisplayPort & HDMI - Windows - docking station - HDMI, DP
Docking station
Docking Interface
USB
Video Interfaces
HDMI, DP
19.2 cm x 8 cm x 4 cm
Gigabit Ethernet
Power adapter DC 5 V
Docking station
19.2 cm
8 cm
4 cm
Gigabit Ethernet
2 x USB 2.0 - 4 pin USB Type A , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x video - DisplayPort - 20 pin DisplayPort , 1 x network - 1000Base-T - RJ-45 , 4 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x video - HDMI - 19 pin HDMI Type A
Security lock slot (cable lock sold separately), VESA 100 x 100 mm, VESA 75 x 75 mm
Security Slot Type
Kensington security slot
FCC, WEEE
Power adapter
DC 5 V
Microsoft Windows 7 / 8 / 8.1 / 10
Kensington SD3650 USB 3.0 Dual Dock DP/HDMI Bundle deal on Kensington SD3650 USB 3.0 Dual Dock DP/HDMI
£218.51
Brand: Kensington
Price Range Ex VAT: 100 - 150
