Preserve the convenience of one-cable connectivity to your entire desktop setup with the SD3600 Universal Docking Station. We all take our laptops to meetings. With a universal dock from Kensington you can disconnect and reconnect your dual HD monitors, mouse, keyboard and all your other peripherals with a single USB cable. Plus, the dock is capable of mounting to the back of a monitor, leaving zero footprint on your desktop.
Dual HD video output
With an HDMI port and a DVI port, you can expand your workspace and increase productivity by adding two external screens. The HDMI connects directly while the DVI port can be connected directly or through the included DVI-to-VGA or DVI-to-HDMI adapter. -
Zero footprint mounting
The dock can be mounted to the back of a 75mm or 100mm VESA-compatible external monitor (mounting plate sold separately), allowing you to keep your desktop less cluttered. -
Extend or Mirror modes
Extend mode allows you to drag an open application to an external monitor so you can work across multiple screens, while Mirror mode allows you to replicate the content that's on your computer display to an external screen. -
Two front USB 3.0 ports
Transfer data at up to 5Gbps with the fast and powerful ports, which are positioned on the front of the dock, which is ideal for devices like smartphones, tablets or external hard drives. -
Four rear USB 2.0 ports
The ideal place to connect all your peripheral productivity accessories like a keyboard, mouse or printer to help keep cables or wireless receivers hidden from view.
- Kensington SD3600 Universal USB 3.0 Dual-2K Dock - HDMI/DVI-I/VGA - Windows - docking station - USB 3.0 - DVI, HDMI - 1GbE
- Product Type
- Docking station
- Docking Interface
- USB 3.0
- Video Interfaces
- DVI, HDMI
- 19.8 cm x 8 cm x 3.4 cm
- 580 g
- Black
- Networking
- Gigabit Ethernet
- Power
- Power adapter
- 2-year warranty
- Product Type
- Docking station
- 19.8 cm
- 8 cm
- 3.4 cm
- 580 g
- Enclosure Colour
- Black
- Data Link Protocol
- Gigabit Ethernet
- 4 x USB 2.0 - 4 pin USB Type A , 1 x microphone - input - mini-phone 3.5 mm , 1 x audio - line-out - mini-phone stereo 3.5 mm , 1 x video - DVI-Analog/Digital - 24+5 pin combined DVI , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x SuperSpeed USB 3.0 - 9 pin USB Type B , 1 x video - HDMI - 19 pin HDMI Type A
- Cables Included
- 1 x DVI-VGA adapter - external
- Security lock slot (cable lock sold separately), VESA 100 x 100 mm, VESA 75 x 75 mm
- Security Slot Type
- Kensington security slot
- Power Device
- Power adapter
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Limited warranty - 2 years
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.20 |
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.06 |
