Protect your iPad Air from just about anything in a mobile work environment with a SecureBack Rugged Enclosure. Dual layer construction offers maximum protection, especially in the corners, while a raised bezel guards against scratches. A built-in ClickSafe anchor lets you quickly attach a ClickSafe lock (sold separately) to deter any theft attempts. The Rugged Enclosure also protects against dust and prevents tampering thanks to its optional cover plates.
Maximum protection
A strong, cushioned layer of rubber surrounds the iPad Air or iPad Air 2, protecting the corners and back from drops and bumps. -
Non-Slip Grip
Rubberized texture makes the case easier to hold and prevents it from sliding off a table or desk. -
Raised bezel and screen protector
Protects the corners and display from scratches and damage. -
Compatible with 75mm VESA mounts
Holes in the back of the enclosure make for a quick and easy installation and attaching Adjustable Kickstand or Rotating Hand Strap.
- Kensington SecureBack Rugged Enclosure - back cover for tablet
- Product Type
- Back cover for tablet
- Black
- 2-year warranty
- Black
Carrying Case
- Protective cover
- Recommended Use
- For tablet
- Cover Type
- Back cover
- Clear screen protector, ClickSafe Security Anchor, non-slip grip, button covers, VESA 75x75, corner bezels for screen protection
- 2 years
