Product
Kensington Rugged SecureBack Enclose iPad Air 1/2
Quicklinx: CRLPWS00 Mfr#: K67738WW
Protect your iPad Air from just about anything in a mobile work environment with a SecureBack Rugged Enclosure. Dual layer construction offers maximum protection, especially in the corners, while a raised bezel guards against scratches. A built-in ClickSafe anchor lets you quickly attach a ClickSafe lock (sold separately) to deter any theft attempts. The Rugged Enclosure also protects against dust and prevents tampering thanks to its optional cover plates.
  • Maximum protection
    A strong, cushioned layer of rubber surrounds the iPad Air or iPad Air 2, protecting the corners and back from drops and bumps.
  • Non-Slip Grip
    Rubberized texture makes the case easier to hold and prevents it from sliding off a table or desk.
  • Raised bezel and screen protector
    Protects the corners and display from scratches and damage.
  • Compatible with 75mm VESA mounts
    Holes in the back of the enclosure make for a quick and easy installation and attaching Adjustable Kickstand or Rotating Hand Strap.
Kensington SecureBack Rugged Enclosure - back cover for tablet
Back cover for tablet
2 years warranty
Apple 9.7-inch iPad (5th generation); iPad Air; iPad Air 2
Carrying Case
Protective cover
Recommended Use
For tablet
Cover Type
Back cover
Clear screen protector, ClickSafe Security Anchor, non-slip grip, button covers, VESA 75x75, corner bezels for screen protection
2 years
Apple 9.7-inch iPad (5th generation) , Apple iPad Air , Apple iPad Air 2
