Kensington Privacy Plg 61cm/24" Wide 16:10
Quicklinx: F46QWS00 Mfr#: 626488
Stock Status: In Stock, Used Stock
2 in stock
£65.09 ex VAT
£78.10 inc VAT
Standard delivery Delivered within 3-5 working days
Kensington privacy filters remove the risk of unwittingly sharing your confidential data with an unwanted viewer. A laptop privacy screen keeps you working without needing to adjust in awkward and uncomfortable positions in order to shield your screen from prying eyes.
Kensington display privacy filter - 24"
Display privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
24"
51.9 cm x 0.039 cm x 32.5 cm
80 g
24"
51.9 cm - 0.039 cm - 32.5 cm
80 g
35 cm x 0.5 cm x 59.5 cm / 380 g
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:10
3H hard-coating
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: F46Q 040228
Condition: Customer return - item has been used but is in excellent condition
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not present or functional  This part of the stock item is present and in good condition  £9.17
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Brand: Kensington
Stock Status: Used Stock
Price Range Ex VAT: 50 - 100
