Protect the sensitive information on your tablet screen with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
- Kensington - notebook privacy filter
- Product Type
- Notebook privacy filter - 2-way
- Installation Type
- Removable
- 33.4 cm 23.4 cm
- 40 g
- Display Screen Size Compatibility
- 15"
- Anti-glare, fingerprint-resistant coating, 3H hard-coating, Edge-to-Edge, +/- 30° visible angle, reduces 42% of blue light transmission
- Designed For
- Microsoft Surface Laptop 3 (15 in)
- Product Type
- 33.4 cm
- 23.4 cm
- Thickness
- 0.39 mm
- 40 g
- Shipping Dimensions (WxDxH) / Weight
- 28 cm x 0.7 cm x 44.5 cm / 260 g
- 15"
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Removable
- Aspect Ratio
- 16:9
- Frameless
- Designed For
