Kensington Privacy Filter 2 Way Removable for HP EliteBook X360 1030 G3
Quicklinx: G84CWS00 Mfr#: 627273
£32.25 ex VAT
£38.70 inc VAT
Protect the sensitive information on your tablet screen with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
  • Blue light reduction
    Filters out the harmful rays by up to 30%, easing eye strain and reducing the chances of blue light interrupting your natural sleep patterns.
  • Installation options
    The privacy screen can be mounted either with the included frameless tab holders that attach to the edges of your monitor, letting you quickly and easily insert or remove the privacy screen, or you can mount it with double-sided tape that adheres directly to the screen for a cleaner look.
  • Anti-reflective coating
    Reduces glare from any outside light sources that can interfere with your viewing clarity.
  • Reversible viewing
    Either side of the privacy screen can be used to different effect. One side has a matte finish to maximize glare reduction, is smooth to the touch and reduces traces of fingerprints. The other side is glossy and provides a clearer view of the monitor screen.
Kensington notebook privacy filter
Notebook privacy filter - 2-way
Installation Type
Removable
Display Screen Size Compatibility
13.3"
HP EliteBook x360 1030 G3
13.3"
Display Filter
Privacy Protection
2-way
Installation Type
Removable
Aspect Ratio
16:9
Brand: Kensington
