Protect the sensitive information on your tablet screen with a Kensington Privacy Filter. Block wandering eyes and keep your data protected.
Blue light reduction
Filters out the harmful rays by up to 30%, easing eye strain and reducing the chances of blue light interrupting your natural sleep patterns. -
Installation options
The privacy screen can be mounted either with the included frameless tab holders that attach to the edges of your monitor, letting you quickly and easily insert or remove the privacy screen, or you can mount it with double-sided tape that adheres directly to the screen for a cleaner look. -
Anti-reflective coating
Reduces glare from any outside light sources that can interfere with your viewing clarity. -
Reversible viewing
Either side of the privacy screen can be used to different effect. One side has a matte finish to maximize glare reduction, is smooth to the touch and reduces traces of fingerprints. The other side is glossy and provides a clearer view of the monitor screen.
- Kensington - notebook privacy filter
- Product Type
- Notebook privacy filter - 2-way
- Installation Type
- Adhesive
- Display Screen Size Compatibility
- 12"
- Designed For
- HP Pro x2 612 G2
- Product Type
- 12"
Display Filter
- Privacy Protection
- 2-way
- Installation Type
- Adhesive
- Aspect Ratio
- 3:2
- Designed For
- HP Pro x2 612 G2
