Kensington Orbit Trackball with Scroll Ring - Trackball - optical - wired - USB
Quicklinx: 7JF0WS00 Mfr#: K72337EU
Recommended Use: Leisure
Type: Trackball
Wired / Wireless: Wired
Colour: Black
Compatibility: PC, Mac
27 In Stock
£44.29 ex VAT
£53.14 inc VAT
Kensington TrackballWorks
idea: Your trackball, your rules.
Download Kensington TrackballWorks software to customise the functions of each of the buttons found on this Kensington trackball. The result is a more productive and truly personalized computing experience. Set your preferred functions or keyboard shortcuts for each trackball button or combination of buttons, adjust the pointer speed and acceleration and do so much more. Best of all, by allowing you to personalise your trackball experience, TrackballWorks makes your trackball work the way you do. TrackballWorks is compatible with the latest operating system versions including Windows 7, Windows Vista , Windows XP and Mac OS.
Kensington Orbit - trackball - USB
Trackball
Wired - USB
Orientation
Right and left-handed
Europe
Movement Detection Technology
Optical
Buttons Qty
2
Scroll ring, removable wrist rest
1 x USB cable - integrated
Microsoft Windows 7 or later, Apple MacOS X 10.8 or later, Google Chrome OS 44 or later
Microsoft Certification
Compatible with Windows 7
Trackball
Orientation
Europe
Input Device
Wired
USB
Optical
Buttons Qty
2
1 x USB - 4 pin USB Type A
Wrist rest
Plug and Play, FCC Part 15
Type: Trackball
Colour: Black
Compatibility: PC
Compatibility: Mac
Brand: Kensington
