The MP230L Performance Mouse removes almost any limitation your current mouse might have, with a combination of wireless freedom and precision tracking on even the most difficult surfaces. A unique track-on-glass sensor uses a high-definition laser that will follow your hand movements on a wide variety of desk surfaces. The 2.4GHz wireless connection via a USB nano receiver means there are no cords to clutter up your desk. The mouse is full-sized, offering complete comfort in an ergonomic, ambidextrous design thats ideal for either right-handed or left-handed users. In addition to the traditional two-button and scroll wheel top, side buttons offer quicker browser navigation. DPI adjustment buttons allow you to control the cursor tracking speed. And with Plug & Play installation, youll be up and clicking almost the instant you plug in.
Track-on-Glass sensor
The unique HD laser can track your hand movements on even the most difficult surfaces, including glass, so you can perform at your peak for increased productivity -
2.4 GHz wireless connection
Using a compact nano receiver, provides the ultimate freedom and mobility for your mouse with a cord-free connection so you can keep your desktop less cluttered -
Full-Size comfort
The two-button, scroll wheel design gives both right-handed and left-handed users the freedom to get the most out of the mouse with contours that allows for pain-free extended usage -
Side and DPI adjustment buttons
The side buttons allow for quicker browser navigation and the DPI adjustments buttons near the scroll wheel let you speed up or slow down the cursor tracking for precision control on your monitor -
Simply insert the wireless USB receiver into your device and you'll be up and scrolling quickly as the mouse driver will download and install automatically
- Kensington MP230L Performance - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- Orientation
- Right and left-handed
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Laser
- Buttons Qty
- 7
- Movement Resolution
- 1600 dpi
- Scrolling wheel, Nano wireless receiver, on-the-fly DPI switching, ambidextrous design
- 3-year warranty
- Mouse
- Wireless Receiver
- Orientation
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Laser
- Buttons Qty
- 7
- 1600 dpi
- 1 x USB - 4 pin USB Type A
- Plug and Play
- Limited warranty - parts and labour - 3 years
