The ultimate locking solution for the ultimate docking solution, the Kensington Lock Module for SD7000 and SD6000 is a complete security system that secures the Surface Pro (or Surface Go/Go2 for SD6000) as well as the docking station. MicroSaver 2.0 technology makes this solution small, yet extremely tough.
- Kensington Lock Module - security cable lock
- Product Type
- Security cable lock
- Product Material
- Carbon steel
- 200 g
- Hidden pin, MicroSaver 2.0 technology
- Localisation
- Europe
- 2-year warranty
- Designed For
- Kensington SD7000 Surface Pro Docking Station - DP/HDMI - Windows 10
- Product Type
- Product Material
- Carbon steel
- 200 g
- Shipping Dimensions (WxDxH) / Weight
- 10.2 cm x 2.5 cm x 17.8 cm / 220 g
- Localisation
- Europe
Security Cable Lock
- Lock Method
- Key
- Limited warranty: - 2 years
- Designed For
