Your Ultrabook is sleek and light, but some of your other essentials? Not so much. Once you add a power brick, your tablet, accessories like a presenter, smartphone, files for the office and more, you suddenly find yourself needing something that can help you carry it all in comfort. Plus you need to make sure your precious Ultrabook and tablet are well padded and protected. That's where the Kensington Triple Trek Ultrabook Backpack comes in. It features fleece-lined compartments that keep an Ultrabook, tablet computer, and even your smartphone safe from scratches. In between the device compartments is plenty of room for files. You'll also appreciate the big accessory pocket that holds your power cord and other necessities. No more fishing around the bottom of your bag trying to locate your keys! The padded back support system and wide, adjustable padded straps make sure you can take it all with you in comfort. The grab handle doubles as a roller strap to help you fly through the airport. And just to prove that Kensington thought of everything, you'll find an easy access storage pocket, perfect for your MP3 player or smartphone, with a headphone outlet so you can talk or rock hands-free.
- Kensington Triple Trek Backpack - notebook carrying backpack
- Product Type
- Notebook carrying backpack
- Black
- Product Material
- 1680D ballistic nylon, fleece
- 290 mm x 140 mm x 395 mm
- 600 g
- Notebook Compatibility
- 14"
- Scratch-proof, zippered, water bottle holder, padded, keyring holder
- Carrying Strap
- Hand grip, trolley strap, shoulder carrying straps
- 3-year warranty
- Product Type
- Product Material
- 290 mm
- 140 mm
- 395 mm
- 600 g
- 14"
- Notebook Compatibility Dimensions
- 33 cm x 23 cm x 2.5 cm
- Additional Compartments
- Mobile phone, headphones, cable, power adapter, digital player, pens, stylus, bottle, tickets, keys, organizer, tablet
- Carrying Strap
- Black
- Limited warranty: - 3 years
